miketheknight20
May 06, 2022Apprentice
RBR750 Shows Offline After FW Update
I just updated the FW on my RBR750, and now I am unable to access the orbi via the app, or by IP (192.168.5.1). I have deleted and re-installed and logged back into the app, still unable to conne...
- May 31, 2022NG must have pushed the update to me. I can now access everything via the browser. App just spins when I put in the password in and I assume times out, but I may need to delete and reinstall. But that will be a tomorrow project.
Just excited that I got a win!
May 08, 2022Guru - Experienced User
Try using a web browser. Are you accessing the routers web page using HTTPS or HTTP and connecting to 192.168.1.1? Try using HTTP if your browser is changing to HTTPS. A factory reset and setup from scratch maybe needed with a wired PC and web browser using HTTP.
- TnknightsMay 09, 2022Guide
"Try using HTTP if your browser is changing to HTTPS"
If there are no ports open, you cannot access via HTTP (port 80) or HTTPS (port 443).
