miketheknight20
May 06, 2022Apprentice
RBR750 Shows Offline After FW Update
I just updated the FW on my RBR750, and now I am unable to access the orbi via the app, or by IP (192.168.5.1). I have deleted and re-installed and logged back into the app, still unable to conne...
- May 31, 2022NG must have pushed the update to me. I can now access everything via the browser. App just spins when I put in the password in and I assume times out, but I may need to delete and reinstall. But that will be a tomorrow project.
Just excited that I got a win!
May 08, 2022Guru - Experienced User
Try using a web browser. Are you accessing the routers web page using HTTPS or HTTP and connecting to 192.168.1.1? Try using HTTP if your browser is changing to HTTPS. A factory reset and setup from scratch maybe needed with a wired PC and web browser using HTTP.
Tnknights
May 09, 2022Guide
"Try using HTTP if your browser is changing to HTTPS"
If there are no ports open, you cannot access via HTTP (port 80) or HTTPS (port 443).
