miketheknight20
May 06, 2022Apprentice
RBR750 Shows Offline After FW Update
I just updated the FW on my RBR750, and now I am unable to access the orbi via the app, or by IP (192.168.5.1). I have deleted and re-installed and logged back into the app, still unable to conne...
- May 31, 2022NG must have pushed the update to me. I can now access everything via the browser. App just spins when I put in the password in and I assume times out, but I may need to delete and reinstall. But that will be a tomorrow project.
Just excited that I got a win!
May 09, 2022Guru - Experienced User
This user posted it worked for them:
I recommend if you try this, disconnect the RBR from the ISP modem/ONT, perform the reset steps, then setup the router from scratch using HTTP and 192.168.1.1 before reconnecting it to the modem/ONT.
Tnknights
May 09, 2022Guide
OK. I knew no one in this thread said "worked" for them specifically. As just in case, I'll put in other APs before I reset, being the untrusting person that I am!!
Thank you!
