miketheknight20
May 06, 2022Apprentice
RBR750 Shows Offline After FW Update
I just updated the FW on my RBR750, and now I am unable to access the orbi via the app, or by IP (192.168.5.1). I have deleted and re-installed and logged back into the app, still unable to conne...
- May 31, 2022NG must have pushed the update to me. I can now access everything via the browser. App just spins when I put in the password in and I assume times out, but I may need to delete and reinstall. But that will be a tomorrow project.
Just excited that I got a win!
CrimpOn
May 09, 2022Guru - Experienced User
FURRYe38 wrote:
This user posted it worked for them:
Reading through those messages, user ecw reported "Ouch... Confirmed with Netgear that is was a firmware update to the latest version and the ONLY way to fix it is a 30/30/30 factory reset." The post does not say that he did the reset and it worked. (probably splitting hairs)
With new customer complaints continuing to show up on the forum, one might wonder if Netgear has halted the rollout process for this firmware update? That would be a sign that Netgear is aware of the chaos the update is causing and taking it seriously. On the other hand, if more people post, "This morning my Orbi...." that is not as encouraging.
Tnknights
May 09, 2022Guide
CrimpOn wrote:Reading through those messages, user ecw reported "Ouch... Confirmed with Netgear that is was a firmware update to the latest version and the ONLY way to fix it is a 30/30/30 factory reset." The post does not say that he did the reset and it worked. (probably splitting hairs)
That's where I've been with this. No one said
