antipatico
May 08, 2022Star
RBR750 unable to connect to router
Hello and Help, my app on both my iPhone and iPad has this message “Unable to connect to router.” I,ve rebooted both the router and the Apple devices as indicated by both mfg. All on my Wi-Fi devices...
- May 26, 2022
Hello All,
If you haven't noticed, the REPAIR has been completed by Netgear. This morning (26, May) my iPhone and iPad Orbi app was able to login and started communication with my router.
Thank you Netgear, greatly appreciated.
Signing off and thank you to all that took part in this post.
Wayne
May 08, 2022Guru - Experienced User
Are you accessing the routers web page using HTTPS or HTTP and connecting to 192.168.1.1? Try using HTTP if your browser is changing to HTTPS. A factory reset and setup from scratch maybe needed with a wired PC and web browser using HTTP.
dbnorton
May 08, 2022Tutor
I have tried multiple PC's with multiple browsers on both http and https. I have even nmap'd the router IP and only 2 ports are showing open and that is port 53 DNS and port 5000 upnp.
