antipatico
May 08, 2022Star
RBR750 unable to connect to router
Hello and Help, my app on both my iPhone and iPad has this message “Unable to connect to router.” I,ve rebooted both the router and the Apple devices as indicated by both mfg. All on my Wi-Fi devices...
- May 26, 2022
Hello All,
If you haven't noticed, the REPAIR has been completed by Netgear. This morning (26, May) my iPhone and iPad Orbi app was able to login and started communication with my router.
Thank you Netgear, greatly appreciated.
Signing off and thank you to all that took part in this post.
Wayne
ecw
May 08, 2022Guide
My Orbi login bombed out today (05/08/2022) as well. I have an Android w/o zero updates recently. I can't log into it via the browser on my desktop nor the app on my phone.
Did NetGear push out an update today or recently that might have caused this? I can't log in to check to see if it was updated obviously.
E
ecw
May 09, 2022Guide
Ouch... Confirmed with Netgear that is was a firmware update to the latest version and the ONLY way to fix it is a 30/30/30 factory reset.
- MB_LoveMay 09, 2022ApprenticeWhat’s a 30/30/30 reset?
- antipaticoMay 09, 2022Star
30/30/30 reset! Both of my apps are frozen in a loop: iPhone on firmware update and iPad detecting product. This is totally irresponsible of NETGEAR. They pushed a firmware update which caused this fiasco, they certainly can push another firmware update to correct it.
- FURRYe38May 09, 2022Guru - Experienced User
Try the 30/30/30 reset and then setup from scratch using a wired PC and web browser at HTTP and 192.168.1.1
