antipatico
May 08, 2022Star
RBR750 unable to connect to router
Hello and Help, my app on both my iPhone and iPad has this message “Unable to connect to router.” I,ve rebooted both the router and the Apple devices as indicated by both mfg. All on my Wi-Fi devices...
- May 26, 2022
Hello All,
If you haven't noticed, the REPAIR has been completed by Netgear. This morning (26, May) my iPhone and iPad Orbi app was able to login and started communication with my router.
Thank you Netgear, greatly appreciated.
Signing off and thank you to all that took part in this post.
Wayne
wreck99
May 09, 2022Tutor
Just factory reset my RBR750 system which has resolved the issue. In the process of installing the new wifi I was given a firmware update. All is well now.
ecw
May 09, 2022Guide
Just got done performing a factory reset myself. All is good over here now even after it updated to the version that broke us over the weekend.
For some reason, the factory reset was more painful that the original install though. Maybe I was just pissed off going into it versus happy when I originally installed it. 🤷♂️
- antipaticoMay 09, 2022Star
Just out of curiosity, did you attempt a soft reset prior to the 30/30/30? I'm asking because, my understanding of a 30/30/30 reset (hard reset) will entail the same process as if I were installing a new router and it is recommended to use a new device name and login password for the main and guest logins which would make me also reconnect 40+ wifi devices. I'm pretty sure I'm not alone on the amount of devices which will have to be reconnected to the network. This is total BS and I still say NETGEAR should forward a fix from their end instead of us end users jumping through hoops just because someone from NETGEAR screwed up!
- CrimpOnMay 09, 2022Guru - Experienced User
This is absolutely not correct. Every time I install a new WiFi router (or Factory Reset the current router) I always use the exact same SSID/password. Have used it for almost 15 years.
- wreck99May 09, 2022TutorIn my case soft reset did not work. As for installation yes it's like new setup. However I just set it up the same way as before and everything just auto reconnected. Even the parental controls carried over which was a nice surprise. The only annoying part for me was renaming the devices that had anonymous names and ensuring they got put under the right kid profile. All in all took me about 20 minutes to reinstall. Not terrible. I agree Netgear should provide a remote fix like they remote broke us. But if you're impatient like me to fix it yourself it's not too bad.
For reference, the new firmware I received upon a factory reset and reinstall was V4.6.8.2.
CrimpOn,
I quote from an article from Router Network, "Once you are done resetting your router, you must reconfigure it. although this is an optional step, it is recommended you do it. Change the wifi name, password and the admin password of the router. You can find the default password of your router on the website. Ignoring to change the default settings makes your router vulnerable to getting hacked. This is what you should always change the default setting after hard resetting them."
/r
I agree. That article recommends changing from the default WiFi settings that are printed on the label. It does not recommend changing from the previous user-selected WiFi settings.
Personally, I think they are "full of it". Every vendor creates default WiFi settings that consist of a vendor specific name, such as ORBIxx, and a password that is often two or three words or random characters. It is not clear (to me) that Netgear uses the same password for every ORBI21 (or ORBI22).
- antipaticoMay 10, 2022Star
Got it, Thank you Sensei. Wax on - Wax off
- MasakiKoiMay 12, 2022Star
I spoke to Netgear. They are aware of the issue. They recommend a factory reset which I do NOT want to do. A software update is in the works. Emergency red flag priority ticket has been open and escalated. Netgear initiated an automatic software update all across the board. This caused the issue. Netgear why didn't you all tested in the lab prior to deploying the software?? Netgear/Engineering team if you are reading this PLEASE have a toggle button option (on/off) on the GUI so that those that don't want the update can turn it off. Let's get the ball rolling and fix this ASAP!!
- antipaticoMay 12, 2022StarAbout time those yahoos fix their mess!!! I like you refuse to 30/30/30 my router.
- kdubiousMay 12, 2022Aspirant
Yep... exactly how I've been stealing your Internet for 15 years. Thanks.
- antipaticoMay 12, 2022StarEnjoy!
- babybillyMay 17, 2022Tutor
So Netgear is going to fix this and save us the trouble of resetting?
- antipaticoMay 17, 2022Star
That's what MasakiKoi stated on 12, May. There has been a lot of people on this post who have completed the 30/30/30 reset on their router with success I might add with reconnecting their app with their router. I tend for, principle sake, want to hold Netgear's feet to the fire to repair the broken connection with an update since they caused it. All of the other electronic manufactures, at lest the ones I associate with, send out updates immediately or soon after they realize they sent an malicious update which caused a problem. Why should Netgear get off the hook by saying we need to cleanup their mistake by doing a 30/30/30 reset to resolve the issue... Some of us value and manage our time as it is associated to $$$. Now if Netgear would comp all of those who conducted a 30/30/30 rest with an additional year of their Netgear Armor program I would be willing to conduct the 30/30/30.
- antipaticoMay 26, 2022Star
Hello All,
Wayne
- FURRYe38May 26, 2022Guru - Experienced User
Backup configuration to file:
Glad it's working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - jbagMay 27, 2022Aspirant
hi
so i am still having this issue.
I cannot connect to the router via the mobile app or web page (wired and wireless). I am using an Android phone and windows 11 and I can connect to the internet.
Looks like there is a fix, so how do we get it?
- FURRYe38May 27, 2022Guru - Experienced User
This help any? https://community.netgear.com/t5/Orbi-App/Orbi-Web-Page-and-Orbi-app-Access-Status/td-p/2223085/jump-to/first-unread-message
in other words, reset. i haven't done that yet. something i am trying to avoid. if this is the only way, so be it. but a fix from netgear would be ideal.
Does changing the local network setting on a Apple device work? What mobile device do you have?
Well if you don't need immediate access, you'll need to wait for NG to make the change or contact them directly.
- antipaticoMay 27, 2022Star
Hello jbag, sorry to read you're still experiencing issues with reconnecting your app to your router. I live in the Apple eco-system and by no means am I an expert in tech but I will tell you all I did was initially before the Netgear fix I: (1) Removed and reloaded the app on my iPhone and iPad and on the iPhone I signed into my account and on the iPad I signed out of my account. Yesterday: (1) On my iPhone I started receiving notices from the Orbi app. (2) I logged into my app on the iPad and connected to the router. Note: I did not do a 30/30/30 rested. Hope this helps with you regaining communications with your Orbi router.
/r
Can you us know if Local Network is enabled for the Orbi app under Settings on the iphone?
/r
Yes it is.
/r
- jbagMay 28, 2022Aspirant
hey
i'm dealing with a droid, pixel 6 pro. i also cannot connect from a web browser on two different windows machines, one of them hardwired to the router.
- FURRYe38May 28, 2022Guru - Experienced User
Try a factory reset and setup from scratch with one of the wired PCs and web browser pointed at HTTP and 192.168.1.1. I'd disconnect the RBR from the ISP modem/ONT while you do this. Press the reset button for 20 seconds then release.
jbag wrote:
hey
