jeff1r
Apr 20, 2022Tutor
RBR850 + RBS850 Orbi App Speed much higher than device Ookla Speedtest
Orbi Application Speed Test = 1,056 down. On same exact iphone device connected to same Orbi main RBR850 router using Chrome and the Ookla Speedtest is getting 218 down. Notebook book computer is get...
Apr 20, 2022Guru - Experienced User
When you run the speedtest in the orbi app, it actually hosts the tests on the main router. So it isn't based on your wifi speeds. When you run it on the speedtest app, it hosts the test on the device the speedtest is being run on. Thats why you see a speed difference.
1. what modem/gateway do you have?
2. what firmware is on the router? And on the satellites?
3. is it only during teams calls that you have lag? Do all devices running teams experience the same thing?
jeff1r
Apr 23, 2022Tutor
Modem = Hitron EN2251 - Hardware Ver: 1C PC15
Base = RBR850 v4.6.7.13
Sat = RBS850 v4.6.3.16
The WiFi devices are running on the WPA/WPA2 security protocol due to some home WiFi components not being able to use the WPA2 protocol. I was thinking about running WPA2 for the main WiFi network, then WPA/WPA2 for the Guest WiFi. Then connect the home components and cameras thru the Guest WiFi. I am dissapointed this very expensive system doesn't have more WiFi network options - as we also have a handful of devices that seem to perform best on the WPA3 protocol.
Thanks again for your help.
- FURRYe38Apr 23, 2022Guru - Experienced User
Sat = RBS850 v4.6.3.16< The RBS should be using same version of FW as the RBR. RBS should be updated before the RBR is updated.
