Drew212
Jan 08, 2023Guide
RBR850 Anywhere Access NOT WORKING AFTER Latest Firmware Update 12-18-22
Cannot get Anywhere Access to work on my rbr 850 router and subsequent two other RBS 850 satellites. This is a direct result of not being able to use anywhere access right after the firmware update at...
Drew212
Jan 08, 2023Guide
You knew where access seems anywhere access seems to be still signed in with the satellites( RBS 850 two of them) but everything is controlled with the router(RBR850)
Every time I sign in it tells me I have the wrong password or something ridiculous like that. Can someone guide me through this I'm no super experienced user I do understand computers but the new Mesh Orbi 6e is having ISSUES WITH ANYWHERE ACCESS with Android phone...Apple ios is having
the Same issues...So it's Not the Phones it ALL POINTS TO a PROBLEM right After Last Firmware Update. There are quite a few number of experienced users having this very same issue. If anybody comes up with an answer I've tried everything I know to do can you please helping any way you can I certainly would appreciate it. Thanks All đ
Jan 09, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended
