tomroper
Apr 11, 2022Aspirant
RBR850 firmware not updating
Hi, my Orbi RBR850 shows that it's running firmware version V4.6.3.16_2.0.51 According to the website at https://www.netgear.com/support/product/rbr850.aspx#RBR850%20(Orbi%20Router)%20Firm...
Apr 11, 2022Guru - Experienced User
This version may not have been put up on NG services for auto update. You can manually update if you feel the need too.
However, if it works, don't fix it.
- tomroperApr 12, 2022Aspirant
Thanks; if it works don’t fix it was my thought too, though with firmware I do worry that I might be missing on improvements to security and performance. Odder still is that the satellite (which works perfectly well) can no longer be found, though it appears as green in the app
