sfergmobile
May 11, 2022Tutor
RBR850 Orbi App not connecting anymore
I love my Orbi, it works so well I never have to mess with it barely at all. So today when I went to show my brother in law how it works I was embarrassed because I couldn't access anything via the A...
- May 31, 2022
I should write an update, my situation has resolved I believe. What I ended up having to do was buy a dongle USB-C to Ethernet LAN like the ports on the back of the Orbi. I procrastinated a bit because it seemed daunting and intimidating. Took a cable and plugged my MacBook in and I was able to access the password reset for my admin account which had been either lost or misplaced or hacked or something maybe? I don't know exactly. It also needed the serial number to the modem and a couple other little things I can't remember. But as soon as I did that I could login to the app in my phone again and everything was ok again. Seems like it anyway. I did not end up needing to do a factory reset or change any settings on my phone like many posts say. My case might be different than yours. Good luck! Wish I knew more
May 11, 2022Guru - Experienced User
You're not the first to report this. Over the last week, we've seen a lot of reports of this.
Some were fixed (if you're on ios) by simply disabling icloud relay and private mac/ip address.
Others did a full factory reset and reinstalled from stock.
Others just decided to wait it out on the next update since everything still works.
sfergmobile
May 11, 2022Tutor
Thanks. I hadn't heard about the iCloud one. I've read about a few other settings and other things to try so I will keep tinkering. Seems like some have had good results doing a full reset of the router, but I'm afraid it would take down the currently working network and then still not let me admin! It's really kind of scary this can happen. I've never lost control of my network before and certainly not while it is still working. Please fix this, Netgear. I have a family I was trying to keep safe when I bought your fancy router. These are not the kinds of things I want to deal with during nap times and in-between making peanut butter and jelly sandwiches
