sfergmobile
May 11, 2022Tutor
RBR850 Orbi App not connecting anymore
I love my Orbi, it works so well I never have to mess with it barely at all. So today when I went to show my brother in law how it works I was embarrassed because I couldn't access anything via the A...
- May 31, 2022
I should write an update, my situation has resolved I believe. What I ended up having to do was buy a dongle USB-C to Ethernet LAN like the ports on the back of the Orbi. I procrastinated a bit because it seemed daunting and intimidating. Took a cable and plugged my MacBook in and I was able to access the password reset for my admin account which had been either lost or misplaced or hacked or something maybe? I don't know exactly. It also needed the serial number to the modem and a couple other little things I can't remember. But as soon as I did that I could login to the app in my phone again and everything was ok again. Seems like it anyway. I did not end up needing to do a factory reset or change any settings on my phone like many posts say. My case might be different than yours. Good luck! Wish I knew more
Javmex8
May 17, 2022Aspirant
When will this issue be resolved and how will I need to update my Orbi system? Will it do it automatically? I also noticed that my internet seems to be working but the lights on the Orbi are not on at all, I push the sync button and it flashes white for a few minutes, please help!
- plemansMay 18, 2022Guru - Experienced User
Javmex8 You can watch the status page at the top of the forum for this. Netgear doesn't release eta's because they don't sometimes don't know exactly when either. The changes need to be validated and then sent to a small group to make sure it doesn't make things worse. It'd be a bad situation if they took it from just not able to access your device to bricking it entirely. But its being worked on and its been acknowledged by netgear (which is rare)
- shandel23May 31, 2022Aspirant
I'm interested in this resolution also as it's happening to me too.
- sfergmobileMay 31, 2022Tutor
