Hspand01
Sep 22, 2024Follower
RBR850
I forgot my admin password since I changed it but when I tried to change it I found out I forgot the answer to one of my security questions. Can someone help me figure out a way to fix this issue I would really appreciate it.
1 Reply
Pretty well the only way out is to reset the RBR850 and get it back to the factory settings.
How do I reset my Orbi WiFi System to factory default settings? - NETGEAR Support
You can then use the passwords and access stuff on the label on the device.
You will then have to set it up from scratch.
Just another user with time on their hands.
