Lilpitter
Apr 15, 2022Follower
RBS10
Need to remove a Satellite that does not work. Not sure on app where to do this. There is not an option for me under devices or under network map. the ma- shows the orbi satellite 3 not working but n...
Apr 16, 2022Guru - Experienced User
try logging in through the browser and going to your attached device list. There should be an option there to disconnect it
