Josephkam
Jun 25, 2022Aspirant
RBS750 - Satellite "Connected" But Not Showing Up
I am having the exact same problem. Both satellites are clearly connected and working as wired devices to both satellites work. But the satellites do not show as connected to the router in both mobil...
Jun 25, 2022Guru - Experienced User
What OS platform are you using?
- JosephkamJun 25, 2022Aspirant
Firmware Version
V4.6.5.14_2.0.54Orbi Router (RBR750) is in AP mode
ISP Router is Arris BGW-210
- FURRYe38Jun 25, 2022Guru - Experienced User
I recommend that you log into the RBS web page using its IP address and update the RBS fw to v.5, Then update the RBR lastly:
When I check for fw updates, the orbilogin page tells me that there’s no updates available for RBR750. I will try again. Are you suggesting that I force a fw update instead of letting it decide for itself?
