Josephkam
Jun 25, 2022Aspirant
RBS750 - Satellite "Connected" But Not Showing Up
I am having the exact same problem. Both satellites are clearly connected and working as wired devices to both satellites work. But the satellites do not show as connected to the router in both mobil...
Josephkam
Firmware Version
V4.6.5.14_2.0.54
Orbi Router (RBR750) is in AP mode
ISP Router is Arris BGW-210
Jun 25, 2022Guru - Experienced User
I recommend that you log into the RBS web page using its IP address and update the RBS fw to v.5, Then update the RBR lastly:
- JosephkamJun 25, 2022Aspirant
When I check for fw updates, the orbilogin page tells me that there’s no updates available for RBR750. I will try again. Are you suggesting that I force a fw update instead of letting it decide for itself?
I just checked - my fw is the latest available for RBR750.
- CrimpOnJun 25, 2022Guru - Experienced User
The Downloads page for the RBR750 product shows the latest firmware as V4.6.8.5
https://www.netgear.com/support/product/rbr750.aspx#download
Quite often, the Orbi web interface "Firmware Update" page does not indicate that newer firmware is in fact available.
Many users, such as myself, prefer to wait at least several weeks after new firmware becomes available before considering whether to install it (or not). My attitude is, "if it ain't broke, why fix it?"
However, the issue is that your system is not displaying a satellite which obviously works and it bothers you. In that case, manually updating to the latest version may solve this problem.
