Josephkam
Jun 25, 2022Aspirant
RBS750 - Satellite "Connected" But Not Showing Up
I am having the exact same problem. Both satellites are clearly connected and working as wired devices to both satellites work. But the satellites do not show as connected to the router in both mobil...
Josephkam
I just checked - my fw is the latest available for RBR750.
CrimpOn
Jun 25, 2022Guru - Experienced User
The Downloads page for the RBR750 product shows the latest firmware as V4.6.8.5
https://www.netgear.com/support/product/rbr750.aspx#download
Quite often, the Orbi web interface "Firmware Update" page does not indicate that newer firmware is in fact available.
Many users, such as myself, prefer to wait at least several weeks after new firmware becomes available before considering whether to install it (or not). My attitude is, "if it ain't broke, why fix it?"
However, the issue is that your system is not displaying a satellite which obviously works and it bothers you. In that case, manually updating to the latest version may solve this problem.
- JosephkamJun 25, 2022Aspirant
Got it. Thanks for your suggestion.
- FURRYe38Jun 25, 2022Guru - Experienced User
NG maybe changing how FW updates are getting to users system since historically thats been problematic at best. So users have the option to manually update if they see newer versions on NG download site or here in the forums.
Think link I posted gives information on how to manually update FW on Orbi systems.
