bulldog00
May 05, 2025Apprentice
RBS750 Link Rate
I did the FW update to 7.2.7.15 following the reset instructions. All seems to be working fine, however, both of my RBS750 are showing a link rate of 6mbps for each device connected to the 5ghz band...
May 05, 2025Guru - Experienced User
Got a screen capture of this?
bulldog00
- FURRYe38May 05, 2025Guru - Experienced User
What was seen on the RBS web page?
Also can check the RBRs web page, I believe on the Advanced Home page and scroll down?
Possible this maybe an odd issue with Orbi app. 🤔
- bulldog00May 05, 2025Apprentice
The RBR/RBS web interface doesnt show link rates; just the connection type. However, it appears i was able to resolve by unplugging the satellite in question for 5 mins, then plugging back in. I then did a reboot of the RBR as well and it seems the issue has resolved.
Seems the app is intermittently reporting the 6mbps link rate when i close the app and re-open it. Clients are still getting the designated speeds; ill assume its an app issue at this point.
