bulldog00
May 05, 2025Apprentice
RBS750 Link Rate
I did the FW update to 7.2.7.15 following the reset instructions. All seems to be working fine, however, both of my RBS750 are showing a link rate of 6mbps for each device connected to the 5ghz band...
bulldog00
May 05, 2025Guru - Experienced User
What was seen on the RBS web page?
Also can check the RBRs web page, I believe on the Advanced Home page and scroll down?
Possible this maybe an odd issue with Orbi app. 🤔
- bulldog00May 05, 2025Apprentice
The RBR/RBS web interface doesnt show link rates; just the connection type. However, it appears i was able to resolve by unplugging the satellite in question for 5 mins, then plugging back in. I then did a reboot of the RBR as well and it seems the issue has resolved.
Seems the app is intermittently reporting the 6mbps link rate when i close the app and re-open it. Clients are still getting the designated speeds; ill assume its an app issue at this point.
- FURRYe38May 05, 2025Guru - Experienced User
Ya think so. There other issues going on with apps these days.
Glad the power cycle of the system helped. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
