tomTWH
Oct 30, 2023Tutor
RBS750 not appearing in network (app)
Hi, I have been trying to add an extra satellite to an existing network of an RBR750 router and 2 RBS750 satellites. After a few days trying with an RBS860 (in vain), I am now trying with a third RBS...
- Oct 30, 2023
Can you ethernet connect the alien RBS to the back of the RBR. Turn OFF the other RBS. Then check the RBRs web page for an IP address that maybe given to the alien RBS in about 5 minutes after connected? If it does give an IP address, can you use this IP address in a web browser and see if you can log in to the RBS using admin and password or same log in as the RBR? The alien RBS probably needs to be updated to same version of FW that's running on the RBR.
Oct 30, 2023Guru - Experienced User
