tomTWH
Oct 30, 2023Tutor
RBS750 not appearing in network (app)
Hi, I have been trying to add an extra satellite to an existing network of an RBR750 router and 2 RBS750 satellites. After a few days trying with an RBS860 (in vain), I am now trying with a third RBS...
- Oct 30, 2023
Can you ethernet connect the alien RBS to the back of the RBR. Turn OFF the other RBS. Then check the RBRs web page for an IP address that maybe given to the alien RBS in about 5 minutes after connected? If it does give an IP address, can you use this IP address in a web browser and see if you can log in to the RBS using admin and password or same log in as the RBR? The alien RBS probably needs to be updated to same version of FW that's running on the RBR.
Oct 30, 2023Guru - Experienced User
tomTWH
Oct 31, 2023Tutor
thank you! almost there I think. I did the FW update. He now appears in the network as a satellite as he should. One minor issue: only hardwired. If I disconnect the cable, he turns purple again and doesn't want to mount wireless.
- tomTWHOct 31, 2023Tutor
It works! Thanks a lot.
- FURRYe38Nov 07, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
