Wilko475
Oct 26, 2022Aspirant
RBS750 satellites not showing up
I have an RBR750 with two RBS750 satellites but cannot seem to view their status in either the iOS app or the web interface. If I reboot the satellites they come up with the blue ring and appear to b...
- Oct 27, 2022
does it show up in the access control section?
With an ip address? you can try accessing them via that.
You can always try a factory reset with clean install (not from backup)
Oct 27, 2022Guru - Experienced User
Are the satellites hardwired into the router?
Are they running through a switch?
Are they wireless backhaul setup?
What modem/gateway is the router connected to?
- Wilko475Oct 27, 2022AspirantNo, the satellites aren’t hardwired and they don’t run through a switch. I do use one of the Ethernet ports on the back of the satellites tho.
Not sure exactly how to do or check the wireless backhaul setup, how do I do that?
The RBR750 is connected to my FTTN modem which is admittedly fairly old.
It seems all the connections are working because all devices (phones, tablets, pcs etc), including the ones connected to the satellites, have access to the internet
