cakelyfe
Mar 01, 2023Guide
Configure RBR50 v2 on iPhone but Orbi not Found
I have had an AC3000 Mesh WiFi System (RBK20) , specifically RBR50v2 that I haven't used in a while. I did a factory reset on it and am attempting to configure I reinstalled the Orbi app and am try...
CrimpOn
Mar 01, 2023Guru - Experienced User
If the Factory Reset "took" and it is not connected to an ISP device, then the Orbi should be at 192.168.1.1.
This is not looking good.
cakelyfe
Mar 01, 2023Guide
It is 192.168.1.1, which I can ping but I cannot accesss the web interface to try to configure it that way either.
