travisinfla
Feb 01, 2024Tutor
Installed 970 a few minor bugaboos
First of all these things are enormous, no putting them in a legrand media enclosure like the 6E - too wide. Will need to mount above it. I upgraded my switch to the unmanaged Netgear x508M with 8x1...
travisinfla
Feb 01, 2024Tutor
Firmware Version
V9.10.4.1_1.1.17
travisinfla
Feb 01, 2024Tutor
1 of 1 satellite is wrong
- FURRYe38Feb 01, 2024Guru - Experienced User
And both RBS appear on the RBRs web page under Basic/Connected Devices page?
- travisinflaFeb 01, 2024Tutor
No just shows 1, see attached, that's what's odd about it, because it's not showing up where it should, in either the phone or MacBook, yet its connected and the only to know that is a couple devices say its getting wifi from satellite 2
Try this, power OFF all RBS and the RBR for 1 minute, then back ON with the RBR. Give 1 minute, then power ON the one RBS that doesn't appear in the RBRs web or Orbi app. Leave the other RBS OFF. Give about 5 minutes while you check the RBRs web page.
