travisinfla
Feb 01, 2024Tutor
Installed 970 a few minor bugaboos
First of all these things are enormous, no putting them in a legrand media enclosure like the 6E - too wide. Will need to mount above it. I upgraded my switch to the unmanaged Netgear x508M with 8x1...
Feb 01, 2024Guru - Experienced User
Try this, power OFF all RBS and the RBR for 1 minute, then back ON with the RBR. Give 1 minute, then power ON the one RBS that doesn't appear in the RBRs web or Orbi app. Leave the other RBS OFF. Give about 5 minutes while you check the RBRs web page.
travisinfla
Feb 02, 2024Tutor
Thanks but no go. I even brought it into the same room as the router. I tried without wired backhaul, still same, also paper clipped reset and tried to sync multiple times and nothing. I'm not sure if I got a bad satellite I'll email support. It could be a software glitch too. It's connected it just doesnt show it where it should and calls it failure when try to add satelilite by phone app or laptop. It's there though, because several devices near are connected to it per the individual devices. Other than that, im getting 1.1 GB wifi speed in living room on 1.2GB plan, and im not even in same room as the orbi router and satellites so thats exceptional
- travisinflaFeb 03, 2024Tutor
last 2 photos just shows its not listed as a satellite or on any map, but its there its named 970, my other satellite is master bed
its listed as a connected device rather than a satellite, bizarre
I cropped this screenshot, it shows as a device, not a satellite
