travisinfla
Feb 01, 2024Tutor
Installed 970 a few minor bugaboos
First of all these things are enormous, no putting them in a legrand media enclosure like the 6E - too wide. Will need to mount above it. I upgraded my switch to the unmanaged Netgear x508M with 8x1...
travisinfla
Feb 02, 2024Tutor
Thanks but no go. I even brought it into the same room as the router. I tried without wired backhaul, still same, also paper clipped reset and tried to sync multiple times and nothing. I'm not sure if I got a bad satellite I'll email support. It could be a software glitch too. It's connected it just doesnt show it where it should and calls it failure when try to add satelilite by phone app or laptop. It's there though, because several devices near are connected to it per the individual devices. Other than that, im getting 1.1 GB wifi speed in living room on 1.2GB plan, and im not even in same room as the orbi router and satellites so thats exceptional
travisinfla
Feb 03, 2024Tutor
last 2 photos just shows its not listed as a satellite or on any map, but its there its named 970, my other satellite is master bed
- travisinflaFeb 03, 2024Tutor
its listed as a connected device rather than a satellite, bizarre
I cropped this screenshot, it shows as a device, not a satellite
