PRenier
Aug 27, 2020Aspirant
Orbi app not showing connection between router and satelites correctly
Orbi app (on iphone) states that my 3 satelites (3 x RBS50) and my outdoor satelite (1 x RBS50Y) are not connected. However, when i login via my MacbookPro (orbilogin.com) i see that all satelites a...
PRenier
Sep 04, 2020Aspirant
Hi Christian, i re-installed the Orbi-app several times but that does not help.
In the folowing screeshots, you'll see the status of the Orbi-app (2 images) and on the same time the status on my Macbook Pro via orbilogin.com.
On my Macbookpro everything looks fine with a GOOD connection. On the Orbi-app, when i go to the networkmap, i can see the satelites but with magenta color witch means that there is no connection. Then when i select one of the satelites in this screen, it says that there are 'No connected devices found' and i know for sure that devices are connected to several satelites...
PRenier
Second image of Orbi-app
- PRenierSep 04, 2020Aspirant
Screenshop Macbook Pro - orbilogin.com
- Christian_RSep 10, 2020NETGEAR Employee Retired
PRenier,
Thanks for the info. I'll have it forwarded to our product teams for review. If you're interested, I can assist with our support team reaching out to you. If you wish to be contacted, please send me a private message with your contact info and serial number.
Christian
