miketheknight20
May 06, 2022Apprentice
RBR750 Shows Offline After FW Update
I just updated the FW on my RBR750, and now I am unable to access the orbi via the app, or by IP (192.168.5.1). I have deleted and re-installed and logged back into the app, still unable to conne...
- May 31, 2022NG must have pushed the update to me. I can now access everything via the browser. App just spins when I put in the password in and I assume times out, but I may need to delete and reinstall. But that will be a tomorrow project.
Just excited that I got a win!
May 11, 2022Guru - Experienced User
Only a 15 second press on the RBR then release is needed. Then walk thru the setup wizard at HTTP and 192.168.1.1.
vsmith30 wrote:
Just curious. Did you have to reset the satellites? Did they also get a faulty firmware update? Plan to try the 30/30/30 reset later this week.
vsmith30
May 12, 2022Guide
So I did the 30/30/30 reset and then reset the satellites. I started the new setup on my iphone and the iphone connects to the orbi, but the app says orbi not found.,l What now?
- Joe221May 12, 2022Star
One of my fears. I take it down and now nothing works. Do do this I have to put faith in the T-Mobile Nokia gateway. Oy.
- FURRYe38May 12, 2022Guru - Experienced User
Factory reset the RBR by pressing the reset button for 15-20 seconds then release. Setup the RBR with a wired PC or laptop and web browser at HTTP and 192.168.1.1. Don't use Orbi app.
