zigor911
Feb 10, 2023Aspirant
Wifi device names in ORBI App as N/A
After latest FW update of my ORBI setup and I am using latest Orbi app on iPhone too: the names of the devices attached to Wifi (either 2.4g or 5g network) now displayed as N/A, though correctly show...
- Feb 13, 2023
Update: what worked for me was to delete the Orbi app, including its data, and re-install from the App Store. It will require to login again to the Netgear account, and then will find Orbi on the local network and will prompt to login as Admin. Now device names are correctly displayed.
Grumpy_Bear
Jan 11, 2024Initiate
Hi Kelly, did you managed to resolve your issue eventually?
KellyOrbi
Jan 11, 2024Apprentice
Yes, it has been resolved for a long time. As I recall, deleting the app and reinstalling did not work. I think i ended up doing a factory reset.
