Nopeynope
Jun 02, 2022Star
Repeating issue with Orbi app -rbr750/rbs750
I've had this issue literally a dozen times in the past 1.5 years..... to the point I almost want to get rid of the system and go with something else. Out of nowhere, the app just stops working. Se...
Jun 03, 2022Guru - Experienced User
there's a notice right at the top of the page about app issues with that orbi app version. You can read it here:
I've got the same and just don't use the app. I just log in through the browser.
Nopeynope
Jun 03, 2022Star
Yes, I saw it after posting.
Cannot connect through browser either.
"Connection refused"
- FURRYe38Jun 03, 2022Guru - Experienced User
You can try this:
Mines up and running and Orbi app IS working.
- NopeynopeJun 03, 2022StarAndroid/PC.
I cannot log in to the admin site to even attempt updating firmware- FURRYe38Jun 03, 2022Guru - Experienced User
If you want to gain more immediate access to the RBRs web page, you'll need to factory reset the RBR by pressing the reset button for 15 seconds, then release. Have 1 wired PC connected to the back of the RBR. Use a web browser and HTTP with 192.168.1.1. Walk thru the setup wizard here.
