SteveB631's avatar
SteveB631
Router not supported
My RBR20 is connected to a CM1000 modem. I use the Orbi app to remote into the network and monitor connected devices. Recently I went to connect and got the device not supported notice. I have erase...
  • CrimpOn's avatar
    Aug 12, 2021
    I have erased and reinstalled app. I have connected locally, logged into the app but was directed to website to reinstall app. Eventually I realized this wasn’t working and gave up. I still cannot remote access on app. I still cannot use the app for my model RBR20. I think the most recent firmware update has discontinued this feature for my model.
    Confirm if this is true and is there a work around or not. Thanks.
    Would be helpful if you can provide more details:
    • Exactly which firmware version is on this RBR20?
    • Can you make a screen shot of the "not supported" notice?
      Use the Browse button in the lower left of the screen to attach it, not the Photos icon, please.
    • After reinstalling the app (iPhone or Android?) and successfully logging into the app using (which credentials? Netgear account login or Orbi web interface "admin" + password?) what is the URL of the web site that it redirected to?
