CBSORBI
Jul 30, 2021Aspirant
Router showing also as satellite
Hi, On my network map it shows an unknown satellite. I inspected the details and it has the same serial number as my router. What is going on here. I am inquiring because I keep getting kicked off th...
CrimpOn
Jul 30, 2021Guru - Experienced User
Have you tried powering off all of the Orbis and then restarting them?
(Not Factory Reset, just power back on again.)
- CBSORBIJul 30, 2021AspirantHey thanks for responding. Yes, I tried that. I actually went the whole 9 yards and completely started over from scratch, reset everything and it’s still there. The only good thing is it’s not losing internet connection anymore.
I think this all started because I was adding a new satellite and for some reason the new satellite took the place of the router in the configuration and turned the router into an unknown satellite. Once I recognized that, I went ahead with the reset.- FURRYe38Aug 01, 2021Guru - Experienced User
Try removing the Orbi app then reinstall it.
