muralimg
Nov 23, 2023Aspirant
Satellite Connection
Hi I have Orbi RBR750 router & Satellite. I want to priorities the connection to my Satellite, is there a way to connect my satellite through wired connection only. I have connected a ethernet Cat ...
CrimpOn
Nov 23, 2023Guru - Experienced User
The most likely suspect is the Ethernet cable. Can you (temporarily) relocate the satellite to the same room as the router and connect them with an Ethernet cable? If that results in a 'wired' connection, there is a good chance that "something is wrong" with the in-home wiring.
- muralimgNov 23, 2023Aspirant
Thanks for the reply. I have checked the cable and is working fine. Still the Satellite connects on wifi only
- CrimpOnNov 23, 2023Guru - Experienced User
If the satellite will not create a 'wired' connection when in the same room, using a short Ethernet cable, then the satellite is defective. What process was used to determine that the existing in-home wiring is "working fine"?
- plemansNov 24, 2023Guru - Experienced User
I was wondering about that "its working fine" statement to.
Some devices aren't as tolerant of sketchy cable as others. So trying the short 6ft cable as a test would be highly recommended.
