muralimg
Nov 23, 2023Aspirant
Satellite Connection
Hi I have Orbi RBR750 router & Satellite. I want to priorities the connection to my Satellite, is there a way to connect my satellite through wired connection only. I have connected a ethernet Cat ...
muralimg
Thanks for the reply. I have checked the cable and is working fine. Still the Satellite connects on wifi only
CrimpOn
Nov 23, 2023Guru - Experienced User
If the satellite will not create a 'wired' connection when in the same room, using a short Ethernet cable, then the satellite is defective. What process was used to determine that the existing in-home wiring is "working fine"?
- plemansNov 24, 2023Guru - Experienced User
I was wondering about that "its working fine" statement to.
Some devices aren't as tolerant of sketchy cable as others. So trying the short 6ft cable as a test would be highly recommended.
