Pricanpapi72
Jun 04, 2024Aspirant
Satellite not showing up in the network
Satellite light was blue for a while. Then it went off. Satellite not showing in the network map
Jun 04, 2024Guru - Experienced User
Does it appear on the RBRs web page under Connected Devices?
What model MESH system do you have?
Pricanpapi72
RBR750 and satellite RBS750
- FURRYe38Jun 05, 2024Guru - Experienced User
What FW version is loaded?
What version of the Orbi app is loaded?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
