jasper285
Apr 11, 2023Follower
Satellites are not showing up been happening for a week now
I seem to have the same problem everyone else has. Satellites are not showing up been happening for a week now. Called customer service they want me to purchase support for 120 dollars because I boug...
Apr 11, 2023Guru - Experienced User
You gave us nothing to go off.
What Orbi system model are you referring too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
What mobile devices do you have?
Orbi App verision installed?
Be sure that any MAC ADDRESS randomizers are disabled on these mobile devices:
- plemansApr 11, 2023Guru - Experienced User
Also, have you checked through the browser?
Might just be an app issue
