Willybob
Jun 10, 2022Initiate
Satellites not showing up on Network Map (Orbi RBR350 with 2 satellites)
I have an Orbi Mesh system (router = RBR350, Firmware version = V4.4.0.10_2.10.63) with two compatible satellites. As you can see from the app screenshot below, it knows it's got two satellites and ...
Willybob
Hi there Kevin,
The satellites are both RBS350's - the mesh system was bought as part of a pack 1 x RBR350 router and 2 x RBS350 satellites. As I said it used to work fine it's only recently that they have stopped showing up on the network map (show in the screen shot) in the app.
Can you explain how to update the Firmware (or make sure it's up to date) when I can't "see" the satellites on the network map? I have doe it with the router as I can see that.
Thanks
KevinLiT
Jun 13, 2022NETGEAR Moderator
Hello Jeffgear,
That is the new look for the Orbi app, but we are still working on improving it.
Best,
Kevin
Community Team
- JeffgearJun 13, 2022VirtuosoThanks for the confirmation Kevin.
- JelberJul 26, 2022InitiateAny news on this?
I have updated everything but am not able to see which satellites are online and which have issues with this current network map.
Extremely inconvenient!- FURRYe38Jul 29, 2022Guru - Experienced User
