Willybob
Jun 10, 2022Initiate
Satellites not showing up on Network Map (Orbi RBR350 with 2 satellites)
I have an Orbi Mesh system (router = RBR350, Firmware version = V4.4.0.10_2.10.63) with two compatible satellites. As you can see from the app screenshot below, it knows it's got two satellites and ...
CrimpOn
Aug 21, 2022Guru - Experienced User
Jacky_or wrote:
How the hell can you position the satellites well when you are unable to see the signal strength?
Blue is Good. Amber is "not so good."
Have you looked to see what the Orbi web interface says about the satellite connection?
Jacky_or
Aug 21, 2022Tutor
Thanks for the info, well that's the first time I saw this information since I open the box.
will try move around and play with the lights.
netgear, simplicity is good, just don't think everyone is a fool and hiding all the information.
BTW what's taking so long to fix the network map? 2 months for fixing this basic feature?
come on....
#RBR350 #RBS350
- FURRYe38Aug 24, 2022Guru - Experienced User
Be sure to submit a problem report if you see issues with the Orbi app:
