Willybob
Jun 10, 2022Initiate
Satellites not showing up on Network Map (Orbi RBR350 with 2 satellites)
I have an Orbi Mesh system (router = RBR350, Firmware version = V4.4.0.10_2.10.63) with two compatible satellites. As you can see from the app screenshot below, it knows it's got two satellites and ...
Jacky_or
Aug 21, 2022Tutor
Thanks for the info, well that's the first time I saw this information since I open the box.
will try move around and play with the lights.
netgear, simplicity is good, just don't think everyone is a fool and hiding all the information.
BTW what's taking so long to fix the network map? 2 months for fixing this basic feature?
come on....
#RBR350 #RBS350
Aug 24, 2022Guru - Experienced User
Be sure to submit a problem report if you see issues with the Orbi app:
