BlackCloud88
Jul 25, 2021Initiate
Separate 2.4ghz on Orbi RBR50v2
Sorry if this has been discussed but I’ve followed what I found to separate these networks but it doesn’t save. After a few minutes the networks go back to being on the same SSID. Is there any other w...
- Jul 25, 2021
The Orbi RBR50 has a feature which many users have found allows them to set up devices which require the smartphone to be attached to WiFi at 2.4G:
- Connect a device with a large screen to the Orbi web interface, http://orbilogin.net
(computer, laptop, tablet)
The user name is "admin" and the password is the web interface password, not the Orbi 'app' password. - Navigate to the Advanced Tab, Advanced Settings (at the bottom), Wireless Settings.
- On the Advanced Wireless Settings page, uncheck the box under Advanced 5G Settings that reads
Enable SSID Broadcast
Click Apply
The router will go through a cycle which takes foreeeeeeeever. - On the smart phone, go into Network settings.
"Forget" the Orbi WiFi.
Search for available WiFi systems.
Select the Orbi WiFi
Enter the password and Connect - The smartphone is now connected to the Orbi at 2.4G
- Note that if you attempt to "double check" by opening the Orbi Attached Devices page, that page takes several minutes to update.
Just go with it. - Open the device smartphone app and go through the setup process.
- After the device is connected and working, undo the process.
- On the web interface, check the box and click Apply
- On the smartphone, Forget the Orbi, find it again, and connect again.
This takes less time to do than to read. It has worked for me several times.
CrimpOn
Jul 25, 2021Guru - Experienced User
Click Apply
- BlackCloud88Jul 25, 2021InitiateGreat! I will try this thank you for the reply.
