atw3
Apr 26, 2023Tutor
Set up Orbi for someone else
Hi, I have an Orbi 750 and love it. I recommended it to my son and plan to set it up for him in his home in the coming days. Question: How can I set up the Orbi for another at their location...
Apr 27, 2023Guru - Experienced User
You could just log in through the browser and set it up that router.
I do it all the time for setting up systems for others.
then they can add it to their account/app anytime.
atw3
Apr 27, 2023Tutor
Thank you Plemens. So confirming -
I assume this is the login: orbilogin.net
Then use the admin account and password that comes with router?
- plemansApr 27, 2023Guru - Experienced User
yes
you can also use its ip address.
When I'm setting it up for others, I actually don't even connect it to the internet. Then have the person setting it up at their location run that part of setup.
- atw3Apr 28, 2023Tutor
Thanks. I'd love to do some of the setup ahead of time, but I've been trying today to log into the new router via browser with no luck.
I guess I'll just do it on location and hope it works 🙂
Thanks much.- CrimpOnApr 28, 2023Guru - Experienced User
Can you connect a laptop directly to the new router with an Ethernet cable?
The router does not have to be connected to the internet.
Open a web browser to 192.168.1.1
If it asks for a login, the default credentials are "admin" and "password".
