cashchris2005
Sep 20, 2021Tutor
Smart Parental Controls Failing to activate
In the orbi app, when I click on smart parental controls > activate now > The app goes through about 10 seconds of "setting up..." until I get an error. The message says "Smart Parental Control activ...
- Oct 15, 2021
Hello cashchris2005 ,
Thank you for sharing your experience with the NETGEAR Smart Parental Controls (SPC) service. We have received a handful of reports similar to yours and have been able to implement a patch for this issue. Will you please try to activate the SPC service again and let us know if the issue persists?
Steps to enable Smart Parental Controls (SPC):
- Log into the Orbi or Nighthawk app depending on which model router you have
- Locate and tap on the Parental Controls tile
- Swipe option to Enable Smart Parental Controls
Please let us know if the issue persists.
Kind Regards,
Christine
Fixmyorbi
Sep 28, 2021Initiate
Has there been a response by Netgear to this problem? Thanks
