davidartiss
Jan 23, 2023Star
Sorry, your device list failed to load. Please try again later.
I just got a prompt on the app to update my system (RBK753) to firmware 4.6.14.3, which I did successfully. However, now, when I head into the app and try to either go into Network Map or Device ...
AdoboLumpia
Apr 09, 2023Initiate
I have the same problem for since update. What I did to resolve issue is click on Network Map….wait until all your orbi and satelite(s) shoes up. Then click on your orbi until all devices connected to it then go back then click on the rest of your satelites one by one depending on how many you have. Then return to home page on your app then by now all your devices should show up in the Device Manager icon. I tried everything for the past few days and this is what I did to resolve my issue. Hope it works for you
- SM915Apr 09, 2023Guide
Thank you, AdoboLumpia! This seemed to work as a temporary measure. I did try using the network map earlier today and it didn't function when I clicked on a satellite, but I hadn't tried clicking on the router first.
However, maybe this doesn't lead to the device list continuing to update? For example, I shut down my desktop computer, but the device list didn't update until I repeated the procedure you outlined. I haven't tested extensively.
I'm not sure how you figured this out, but I appreciate it! I'm thankful that I wasn't in the same situation as some others who needed to be able to reenable/disable devices today, but hopefully this works for everyone as at least a temporary measure. - ajay__Apr 09, 2023InitiateThanks for the workaround. Can confirm that accessing Network Map and then loading the router followed by each satellite causes the device lists to load. I have been unable to finally unpause the device I needed to! Still very poor from Netgear, especially when they make you pay for parental controls which is a free (and better) service on Google wifi.
Another workaround if ever needed is to temporarily connect a device via Ethernet cable instead of wifi. Obviously only applies if the device has an Ethernet port, like a laptop or console. This will appear as a separate device on the network.- lostdocApr 10, 2023GuideNot sure if it works for others but I seem to see a list of devices now. Wonder if something was quietly pushed…
