davidartiss
Jan 23, 2023Star
Sorry, your device list failed to load. Please try again later.
I just got a prompt on the app to update my system (RBK753) to firmware 4.6.14.3, which I did successfully. However, now, when I head into the app and try to either go into Network Map or Device ...
ajay__
Apr 09, 2023Initiate
Thanks for the workaround. Can confirm that accessing Network Map and then loading the router followed by each satellite causes the device lists to load. I have been unable to finally unpause the device I needed to! Still very poor from Netgear, especially when they make you pay for parental controls which is a free (and better) service on Google wifi.
Another workaround if ever needed is to temporarily connect a device via Ethernet cable instead of wifi. Obviously only applies if the device has an Ethernet port, like a laptop or console. This will appear as a separate device on the network.
lostdoc
Apr 10, 2023Guide
Not sure if it works for others but I seem to see a list of devices now. Wonder if something was quietly pushed…
