cargal
Oct 19, 2024Aspirant
"Sorry, your device list failed to load. Please try again later."
Suddenly received - "Sorry, your device list failed to load. Please try again later." - can't find the resolution in the community - any help?
JWS9518
Oct 20, 2024Luminary
There was a recent update of the Orbi app the last couple of days...try updating that if you have not already. If that doesn't work, I would close the app and then clear the cache of the Orbi app and see of that helps.
cargal
Oct 20, 2024Aspirant
Thanks for the suggestion, but that did not work .... i got the following error when trying to check for firmware update...."There was a problem checking firmware update"
- JWS9518Oct 20, 2024Luminary
Try uninstalling the app completely, rebooting your phone and then reinstall the app through the Android/Apple app store. Then re-login into the app after installing again and see if that helps.
If that fails, try rebooting your Orbi network by unplugging everything for 30 seconds.
And as a last resort, you could also do a hard reset and see if that straightens things out. Plus, make sure your Orbi has the latest firmware.
- cargalOct 21, 2024Aspirant
This is getting more interesting ... removed and downloaded the Orbi app on my iPhone - still does not work ... however it works on my iPad perfectly - have never had the problem on my iPad .... i have checked all settings on iPad and iPhone and they are the same ... go figure ...:(:(
