cargal
Oct 19, 2024Aspirant
"Sorry, your device list failed to load. Please try again later."
Suddenly received - "Sorry, your device list failed to load. Please try again later." - can't find the resolution in the community - any help?
cargal
Oct 20, 2024Aspirant
Thanks for the suggestion, but that did not work .... i got the following error when trying to check for firmware update...."There was a problem checking firmware update"
JWS9518
Oct 20, 2024Luminary
Try uninstalling the app completely, rebooting your phone and then reinstall the app through the Android/Apple app store. Then re-login into the app after installing again and see if that helps.
- JWS9518Oct 20, 2024Luminary
If that fails, try rebooting your Orbi network by unplugging everything for 30 seconds.
And as a last resort, you could also do a hard reset and see if that straightens things out. Plus, make sure your Orbi has the latest firmware.
- cargalOct 21, 2024Aspirant
This is getting more interesting ... removed and downloaded the Orbi app on my iPhone - still does not work ... however it works on my iPad perfectly - have never had the problem on my iPad .... i have checked all settings on iPad and iPhone and they are the same ... go figure ...:(:(
The fact that it works on the iPad and not the iPhone - is it not safe to assume that it is not related to firmware or is that an incorrect assumption on my part?
- CrimpOnOct 21, 2024Guru - Experienced User
Some recent firmware releases on specific products have prompted more questions on the forum than usual, so "it depends".
What Orbi model/firmware release is this?
I would love to hear what happens when you select Local Connection on the iPhone (assuming that it is actually connected locally to the Orbi system)
