EmilyParker
Apr 01, 2020Aspirant
SOS. Please help!! Kids have online school tomorrow!
I cannot get my internet working for the life of me and I'm not technologically savvy att all. I reset Orbi router to factory standards to the whole process over again and everything connected exce...
Apr 01, 2020Guru - Experienced User
What modem are you using?
Who's your isp?
EmilyParker
Modem is ARRIS dual band WiFi and ISP Comcast xfinity
- EmilyParkerApr 01, 2020AspirantOrbi has purple light and won’t connect to WiFi
- plemansApr 02, 2020Guru - Experienced User
EmilyParker wrote:
Modem is ARRIS dual band WiFi and ISP Comcast xfinityA model number helps more. but eitherway, if the arris has its own wireless, then you're in a double nat. It means you have 2 active routers on your network. The 2 easiest options?
1. Place the Orbi in AP mode (access point). this turns off its routing features and lets the arris handle routing. wireless and ethernet still work fine.
2. Or place the arris in modem only/bridge mode. this disables the routing/wireless on the arris and it acts as only a modem.
Purple on the orbi means the wan isn't connecting. Which would be the issue in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
