rbroman
Mar 29, 2025Aspirant
Unable to connect an ORBI RBS750 satellite to an ORBI67 router
After many attempts, I'm unable to connect an ORBI RBS750 satellite to an ORBI67 router. I've been using the ORBI app in an iPad, and following the steps therein, and the app doesn't discover the new...
- Mar 30, 2025
The Netgear web page is pretty clear. Only one satellite shows as compatible with the RBE771 router.
CrimpOn
Mar 29, 2025Guru - Experienced User
Please identify the actual model number of the router from the product label on the bottom.
rbroman
Mar 30, 2025Aspirant
Thanks for your help CrimpOn!
The router is an RBE771, the working satellites are RBE770 and the non-working satellite is an RBS750
I'm assuming the conclusion is that the RBS750 is not compatible with my RB771 router and/ or the working RBE770's, please confirm.
Also .... are there satellites other than the RBE770s that are compatible with my existing RB771 router and the working RBE770's,
- CrimpOnMar 30, 2025Guru - Experienced User
- rbromanMar 30, 2025Aspirant
Got it, and thank you again for helping me. There's a lot of misinformation on the net, but I never found the ORBI compatibility matrix until you pointed it out to me.
Thus, I could have saved myself a lot of time by asking here about compatibility first.
