MMcD
May 13, 2022Guide
Unable to connect to Orbi RBR750
Last night one of our streaming devices said it was offline so I checked the Orbi app on my iPhone to see the network status. It said it was unable to find the Orbi router. It did find the two sat...
- May 27, 2022
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
MMcD wrote:
UPDATE:
I waited almost two weeks to see if the problem would fix itself (I never lost internet access so I could afford to wait). No luck, so today I resolved to follow the instructions to reset the router.
I decided to try to login from my desktop one last time using 192.168.1.1 and it worked! So I guess something was indeed fixed remotely.
So I didn't have to reset the router and all the rest.
The Orbi app on my iPhone still wouldn't work (didn't find the router) but logging out and back in fixed that also!
Hurray!
May 13, 2022Guru - Experienced User
we've seen this a lot lately.
Some were fixed with simply disabling icloud relay and private mac/ip address.
Others needed to do a full factory reset and reinstall.
Others have decided to wait to see if a new firmware/app would fix the issue.
Kind of up to you which route you'd like to take.
- MasakiKoiMay 13, 2022Star
Netgear is fully aware of the problem. Netgear if you are reading this.....The new Orbi app update for the iPhone last night 5/12/22 did NOT solve the problem!!!!.
Orbi app update version 2.17.0.171 (5/12/2022).
- MMcDMay 13, 2022Guide
Thanks for the tip about updating the Orbi app. I'm still on an older version.
But I don't think this explains why I can't get into the router from Windows 11. (Or does it?)
I am using a Mac and also not able to login.
Thanks for the quick response!
I just checked and my phone didn't have iCloud relay activated. I then disabled the private mac/ip feature and the app still can't find the router. But would either of those explain why I can't get in from a Windows PC?
I don't mind waiting at the moment. We still have full internet service. But will the firmware update happen by itself? I can't get into the router to check for updates and install them.
One final question: what do we lose, if anything, by doing a full reset? I guess we will need to reconnect devices using the restored default password. Is that about it?
Mark
- CoffeecupMay 13, 2022Star
I was in the same boat about waiting for FW upgrade. I got tired of waiting even though my WiFi worked but no Orbi app functionality. I crossed my fingers and did the factory reset. You can keep the same SSID and password after the reset ( initially you'll be using the default SSID and password on the back of you Orbi). I also deleted and reinstalled iPhone Orbi app and made my iPhone "forget" my current SSID. My rational was that the new reinstalled Orbi app would connect easier to the Orbi default SSID. Sorry for the divergence but to answer your question, all your devices should connect as long as you use your same SSID and password.
Thanks, Coffeecup. That is all very reassuring!
