bdahake
Jul 08, 2020Tutor
Unable to disconnect wifi access to connected devices
I am unable to block internet/wifi access to connected devices using the orbi app. The status appears as "Blocked" under access control for a device which I want to block. Inspite of this status, th...
- Jul 12, 2020
I updated the latest firmware to refresh the system of some bad file errors.
You will need a wired connection to your router. Please update the satellite first and then the router. This fixed the issue.
Dgust
Jul 09, 2020Aspirant
I am having the same issue, just set up new RBR753s (costco) system yesterday and have the same issue. Slide switch in app over to pause/disconnect internet for a specific device but devices stays connected. Firmware is updated and rebooted the system after set up.
- bdahakeJul 12, 2020Tutor
